- Dec 28, 2019
Hi, we recently lost an iPhone 6s down a toilet at a National Trust property. It was handed in fortunately.
I've fixed my water damaged 5c and it's still going strong 3 batteries later so I have some experience.
This is the story:
1. Got it home, opened it up and dried it with kitchen towel.
2. Put it in a sealed container, with rice, for 4 days - swapping for fresh rice halfway.
3. Fitted new battery and it started up ok.
4. Screen however was looking like Mt Everest, complete with crevasses.
5. Was happy to wait for improvement; as with the 5c - but ordered a (quality) replacement screen.
6. Whilst waiting, my wife suggested checking that it would still make calls ok. I had innocently assumed it would.
This is where my question to you guys begins.
1. I put the sim in and switched on; all looking good.
2. I phoned it from my 5c and it responds fine the first time, and the second.
3. Third time however it doesn't answer and fairly soon it's "no service"
4. I turn it off and on and it does the same thing again. I find that if I call again quickly it lasts a bit longer before losing the signal BUT only around 30 seconds max.
5. I followed some advice to "reset network settings". This seemed a bit better but I think that was wishful thinking and I'm soon back to the 3 or 4 successful calls in 30 seconds before it loses signal.
6. As well as regaining signal by switching the phone on and off I find I can "reboot" a signal by toggling the "airplane mode" but still the same result.
7. Next advice was to update the iOS from 12 to 13. Again, no change.
8. I checked with Vodafone that all was well their end, which it was. They suggested I swap SIMs between my 5c and this 6s - sensible idea - this ruled out a SIM issue as the problem behaviour remained with the 6s.
9. Finally, just before this cry for help, I decided to just try one single solitary call from my 5c to the 6s (whereas before I would always hang up and ring again straight away)
10. This time the signal held firm (not giving up after the usual 30 seconds) and held firm. I finally terminated the call after 15 minutes of strong signal.
Hopefully there's enough info here to give some clues as to what my problem is. I've no idea how the cell transmit/receive system works or where its components are located so I'm really in the dark.
Many thanks for bearing with this longish post and for any suggestions.
Kind regards,
Mike
This is the story:
Kind regards,
Mike
