4.3.3 problem
4.3.3 problem
gray_mouse
Sochi, Russia
In 4.3.3 with ultrasn0w (1.2.3 if I'm not mistaken) there is a prob which I didn't had in 4.3.2, and 4.3.1..
Problem is as follows. 3G/EDGE not working. i.e. data IP address is blank in SbSettings, and internet don't work. Phone otherwise works, can make and receive calls and SMS.
SIM card works, when I insert it into iPad, there is internet.
Fixed it by redoing the sn0wbreeze 2.7.1 jb. Basically wiped everything and re jb.
Now it either was one of the apps, settings, or jb was bad.
No. Said it too early. And was wrong about second SIM working properly.
I think this has to do something with battery improvements in 4.3.3.
Ok. Went back to 4.3.2 with Ultrasn0w 1.2.3. Problem is gone. Thus it does appear to be the great new battery saving futures in 4.3.3. What it appears to be doing is getting IP for 3G/GPRS when you need connection. Like when browsing web. But when your phone is locked, interface is off. Basically in 4.3.3 it has a problem coming back up. In 4.3.2 there is no such problem. Go figure.
For now, I'll stick with 4.3.2..... To hell with battery saving future that don't work right, and to hell with that tracking crap that I know for a fact is a CIA mandate thus nothing was really done about it.
