5s Help
5s Help
smo1898
My current phone broke on me so I'm back to using my 5s. I cant for the life of me remember the passcode I put on it and obviously can't get on it.
Also my home button is broken which makes entering DFU and resetting it not an option
Never synced it to my computers either so connecting to itunes isnt an option without the passcode.
I dont mind having to reset the whole thing or do whatever it takes so any ideas would be helpful.
Welcome to iPhoneForums, smo1898!
If you have an iCloud ID, and "Find my iPhone" is enabled, use it to erase your iPhone. This will remove the passcode as well.
Login to iCloud, select "All Devices" at the top. Choose your iPhone, and erase it.
Hope that helps.
