- Nov 10, 2012
can anyone give me an authoritative account whether or not aluminum cases cause problems with an iphone 4s? there is so much untrustable info on the net, its hard to discern. i am specifically referencing the i+case, which i would like to buy but i am not sure if it will be problematic.
i also wish to install a 3m carbon fiber skin onto my 4s as well. now i also read on various places online that putting a piece of foam on the side of an iphone 4s, on the side where the antenna would be located underneath, will prevent signal blockage.
is that true? if so, would the 3m carbon fiber skin also prevent signal issues?
so for me specifically, i plan on putting front, side and back 3m carbon fiber skins onto my 4s and then installing the i+case.
does that sound like a working configuration?
