Angry Birds Loads once problem
Status
Not open for further replies.
MikeCorruption
Birmingham, UK
This has happened so many times and it's annoying, I have tried version 2.0.6 , 2 and 1.6 and the same problem occurs, Angry Birds will load first time fine, but as soon as I exit the app and close it from the background it never loads again, I will click on it and it'll just stay on a black screen then go back to the spring board, it only occurs with this app, any advice?
Which Angry Birds do you have? The original is on version 2.0.2. If you have that one, just upgrade it from the App Store ... should fix your crashing issues. The same applies to all the versions: upgrade and use the latest versions from the App Store (besides, how can you stand seeing that little red update badge? Drives me so nuts that I have to upgrade right away!).
Anyway. Try that?
Marilyn
MikeCorruption said:
Mine is an IPA file, so cannot be updated from app store
IPA's only mean one thing... a cracked app! Perhaps the issue is you're using a pirated version of Angry Birds... which we simply will not allow discussion of. THREAD CLOSED!!
Status
