- Sep 29, 2014
Just over a month ago i started noticing that my phone was draining more than usual in standby about 10% in an 8 hour period. Not as bad as some of the horror stories you read about but more than it should be. Usually i get 0 to 1% battery drain during standby while i sleep. So I started experimenting. Ive tried turning off wifi one night then the next turn off location services. and turned off background usage and then tried turning all notifications off then tried it in airplane mode and another night tried just turning off cell services and none of these really had an affect on the battery drain it was all about 10% in the 8 hour period or so.
So i tried resetting everything on the phone and restoring it back through icloud and didnt work so then the next night i tried wiping everything without restoring and it didnt work. Then ios8 came out and i thought maybe would help tried updating to that and nothing. Then started the wipe off again without restoring and same thing. then tried doing all these steps from itunes rather than restoring from cloud. and didnt make a difference. So i got a new battery from ifixit and to very much my surprise it didnt make a difference at all...
Am I missing something??? Thanks!
iphone 5 with ios8.02
