I'm not sure if there is a thread on here or not, but here are my personal experiences with battery life so far.
I am noticing a much slower battery drain when I turn wifi off while I am NOT connected, or anywhere there is NO wifi available. I attribute this to the fact it is always searching for a hotspot.
However, whilst on Wifi, I am noticing a slower battery drain, as long as I am continually connected, and getting a decent signal.
So, IMO, turn wifi completely off if you know you are not using it, but if you have wifi available, use it. That's what I do, and I get to the end of a day (8:00am - 5:00pm) with about an hour of phone calls, 30 minutes of browsing, hour of games, 20 emails, and about 100-150 texts with ~70% battery left. This is at work where there is no wifi, and I went into settings and switched off Wifi. O, and brightness is set to Auto, and 50%.
I am ONLY posting this because I know people have always debated whether or not wifi is a battery saver or drainer, so I decided to post my experience. So, I am not promising the same with you, but it might be something to try out.
