I have the iPhone 5 with the latest version.
I am no longer able to see what is causing the most usage on my battery. When I go to Settings>Battery then I see under Battery Usage the following: Battery information will be available after using iPhone for a few minutes .I used to be able to check it without any problems. Not sure if this happened after the latest update. Anyone know other things I could try? I did shut it off. It is the factory phone.
