Blue tooth problem
alpinette
I have the I phone 3GS and recently purchased the parrot Bluetooth head set. When talking on it people tell me I fade in and out really bad. Had someone else use it with there phone to see if it was the headset but worked fine. Went to apple and told them about it and were really good about it and gave me a new phone. Problem is still having the same issue. Any one had this problem or know what is causing it.
Just day before i had the same issue with my i Phone, I was trying to connect blue tooth to my car build in calling system and I Phone started acting wired as won't turn on after doing a lot of Google search only solution I found was to just restore the system and firmware and so far that's the only solution I am aware of. Good Luck
