Bootlogo Help?
Bootlogo Help?
shawn744
hey guys, i hope i'm allowed to ask this but i've been having trouble getting my bootlogos to work downloaded from cydia...all of them say that i have to be jailbroken with greenpoison...should that matter? i mean i have the animate program istalled too...does that mean all the redsnow people are lucked out?
thanks for the help.
-shawn
I know that there is a version of redsnow which allow you to jailbreak with a costom bootlogo. Still i've never tried it my self nor never tried anything related to bootlogo, but if that matter a lot for you, why don't you try out the greenpoison like others suggested? You have nothing to lose except time, as long as you make sure that you've backed up your iOS in itunes.
-shawn
it works with redsn0w as well and they work on all firmwares after 4.2.1 but if your on that fw then use greenpois0n or use redsn0w for later fw, i am on 4.3.2 and they work just fine, got a matrix one..
but try uninstalling it and using redsn0w to install the right version that will work
I used redsnow and my boot logo works. If you already jailbroke it. Open redsnow like your going to jailbreak it. When the menu comes up. Just unclick cydia and click install bootlogo from menu. Let it run and you should be fine. The reason to unclick cydia so that the programs don't interfere with each other. I googled it hope that helps
