breakout cable with audio in and out, and usb charger?
Svante
Hi,
does anyone know of a breakout cable for the 30-pin connector, that gives:
audio out (left/right)
audio in ("mic in", thats mono on iPhone)
USB connector so it can be charged on the same time?
Could look something like this for example:
Ive googled and found similar breakout cables, that gives audio out, video out and usb charging.
Close but no cigar.
Yeah man....Apple sells them.
I have a Griffin brand one I use for playing music through my HDTV.
Amazon man.....Amazon.
It's got the red, whit, yellow plug...plus a USB plug for charging. Plugs right into my TV, so I can watch Netflix through my TV and charge my phone at the same time.
Not sure "exactly" what your asking...but it basically looks like your asking of they exists.
They do...and they are all over Amazon and similar web sites.
Thanks zig9449,but thats not what i am after.
it should give
- audio out (left/right)
- audio in ("mic in", thats mono on iPhone)
- USB connector for charging
the "audio in" is the hard part to find.
the video connection is not of interest.
any ideas much appreciated.
it should give
So that that whatever is said into the phone is projected out through whatever it is you are connecting it to?
not quite, I'd like to use a guitar tuner (needs the audio in) and play music files on the same time (audio out).
And charge at the same time, so as not to worry about running out of battery.
And not using two cables (which would be possible, of course).
