CameraButtons Help!
CameraButtons Help!
Matrixnubee
Long Beach, Ca
So I installed the camera buttons tweak from Cydia, the .99 one. It seems not to work at all...
I set the tweak to "enable" then set the take photo to the volume up setting, and when trying to take a photo using the volume up button nothing happens, the picture doesn't take.
Am I doing something wrong? I rebooted and resprung and it's still not working.
Someone please help, a paid app should work right :(
What iOS are you on? Did you read very will the supported iOS for that tweak before purchasing it?
So after further investigating ive found that the only feature that works is the shake to take picture, but the volume buttons still do nothing :(
Does BiteSMS have anything to do with it?
No i don't think so.
