connection problems
connection problems
andreaspf
Hey guys,
since a few weeks I have many problems with my iphone.
First of all it looses connections very often while I'm calling. Suddenly it says "no servcie" and a few minutes the network is back online.
Second problem is that it jumps to simlock several times a day and i have to put i my code every time again.
Anybody knows a solution?
For the 'no service' part, it could be that the area where in you're taking a phone call could have faulty or low signal reception. For the sim lock, you might want to remove the passcode you've set so that your iPhone won't ask you for it anymore :)
Hey guys,
what iOS are you using? you can try to factory restore your iOS and if it still doesn't cure the issue, then take it to the apple store.
