Converting PDF into ebooks in iPhone_need help
Dmdbanary
Hi,
Want to know if there is any techneque to convert PDF books into e-books in iPhone?
Will be appreciate for any ideas.
iBook, from Apple, displays PDFs naturally. It might help to know why you need to convert something that already natively works to a non-industry standard format so that you get a better set of answers.
You can sync PDF to your iPhone using iTunes and you will find them in the iBook app on your iPhone, if you do not have the iBook app installed yet then install it. Also you can use your computer to upload your PDF to your email and then open your email box on your iPhone, find the mail with the PDF files and there is an option to open them using iBook.
Want to develop app like "book library", but some books are about 400mb in PDF. Such a problem.
