Drop i5s in WATER!
Drop i5s in WATER!
EyePhone4
757, VA.
Yes, i'm all the above! I accidently dropped my phone into a bowl ful of water but, i do have it in a otterbox defender. So it went in all the way got it out shut it down a little, turned it on everything working like a CHAMP! Only thing my speaker don't sound as loud as it was. I want to ask if anyone knows where the water sensors are so I can check if there's water damage, thanks fellows
It's on the side there is a tiny hole that shows if your phone dropped in any water it turns red and you might wanna take the phone apart and put it in a bowl of rice and leave it for 24hrs so everything can come back on normal
Thanks for the info. I did check the side where the SIM card is inside"IT'S WHITE AS A GHOST", and it's works fine LOL! That's where I'm posting from 😜
Sent from 4s Tapatalk
