Is there a way to turn up the volume in the ear piece? When I use the volume buttons on the side they just turn up the ring volume. Thanks.
holophyte said:You can Tap the screen and that will show you the volume control in-which you can slide that up or down to your chosen preference.
iCrank said:What? That doesn't work.
holophyte said:Well that's how I work mine fella. I tap the iPhone 4 screen it then brings up the volume controls I then set the volume ..... Simples! Or is this topic on about something else?
iCrank said:Are using activator
holophyte said:Who me or you?
iCrank said:You. I can't click on my screen and increase the volume. I actually have to open some kind of media otherwise my ringer will just raise.
holophyte said:You can't? Open the iPod play a song or video hit the screen it brings up the volume control. Isn't that what your on about when using an ear piece and the volume?
iCrank said:That's exacty what I'm saying.
jorob said:I just tried that and it worked for me -- double-clicking on the home button brought up a menu along the bottom of the screen that wasn't there before. Sure enough, two swipes to the right and a volume slider appeared that I hadn't been able to find before. Ta-da!! I can hear my callers now.
iCrank said:Oh snap...I just noticed this. Wow. This is the first time I ever noticed this..lol
darkstar2007 said:Really? I replaced mine with a brightness adjuster lol. It's more useful IMO.
