ThatTechyGuy
iPhoneForums News/Reviews
Check out this neat little iPhone 16 Pro Max case!
It's built for the Delta/Retroarch emulator, and the controller part can slide onto the back or the front of the case whenever you want it!
I enjoy playing emulators on the iPhone, but my biggest complaint is the touchscreen controls. You can always use a wireless controller, but this is the best all-in-one solution that you can always have with you.
Check it out:
(It's also available for the iPhone 15 Pro Max)
That's really cool! I wonder how well the d-pad and buttons actually work?
From what I can tell, they seem to be touch buttons that emulate a finger on the screen.
I can see it working well, but not the same as a controller. It would also rely on the app supporting it, so you couldn't just use it with any app.
The nice thing is it doesn't need to be paired to your phone, and it doesn't require a battery. I don't think that's too bad for $20.
