Headphones and static noise at low volumes
H ramsay
Hi guys,
I've recently got my hands on a 4s (second hand so out of warranty), currently running IOS 7.0.2 which has been going great, aside from when i try to listen to music. At under 75% volume all i can hear is a quiet sort of static. This stops when I turn it up to 75%ish volume but that is somewhat deafening. I've tried factory reset and a hard reset but no luck so far. I also know that it isn't the headphones as I use them on my computer, and a different pair of headphones results in the same issue. The issue also does not happen when on the phone. Any tips or tricks that would get it to work? Thanks!
Possibly the headphone port's problem. If you have a pair of suppressed air, give it a go in a few different angles since debris/particles may be in there. If that doesn't fix it, there might be a short in the device.
