HELP! How to upgrade 14pro max with iOS beta18.0 to 15pro max with Beta 18 installed
thecounof
United Kingdom
Just wondering, if I now have an iPhone 15pro max, will I be able to do the usual upgrade from older iPhone 14 Pro Max phone to newer 15 pro max phone, even though mine is running the beta iOS 18.0 (22A5338b) ?
I am really concerned I might lose my data as maybe the Beta won’t just transfer straight will it with a standard usual phone to phone migration as I have done before? It’s the first time I have ever installed betas since the last time I upgraded iPhone.
The iPhone newer 15 pro max has 512gb and so has the 14pro max
I have 328gb free on the 14 pro max
I "think" I have everything backed up to the cloud but never 100% - hope I have.
If I'm understanding right, your 14PM is on the iOS beta, and the 15PM you just got is still on iOS 17.
In this case, you'll want to wait a little bit until iOS 18 is released to the public, most likely today or tomorrow. Then upgrade your 15PM to the official iOS 18 release.
With your 15 on iOS 18, you should have no issues transferring your data over from your 14 to your 15. I did this last year when my 14 was on iOS 17 beta, and my 15 I got was on 17.0.
Hi there, thanks for responding. I’m not sure what the 15PM is on as it’s in set up mode?
How can I check this when it’s in set up mode?
Hopefully today they will release 18 as I have sold the 14PM on eBay and the buyer is waiting for me to post it. 🙃
Just hope he’s patient a little more whilst I wait for 18 to go live. Which I suspect I will somehow need to update the 15PM but got no idea how you do this?
iOS 18 will be launching next Monday...
You can try restoring the new iPhone from a backup when you are in the setup process. It's possible that when you select your iCloud backup, or quick start from the new iPhone, it will prompt you to update your iPhone's software to the iOS 18 beta.
Oh that sounds good if it does! I guess I need to try. That said, one of the first things is it asks you to transfer the eSIM over right at the start but I am concerned if it doesnnrwoek with the iOS18 beta situation then it might cause issues? Is it possible to skip and then sort it out once I have checked if it does prompt me to upgrade as you say?
Yep, you can always skip as long as you have access to WiFi.
You can easily transfer an eSIM in settings, here is the Apple article linked:
Didn’t realise that. Sounds like it’s doable then…. Thanks
Well it doesn't work. Firstly it wouldn't automatically migrate from the phone being nears it gets past the scan of one phone to another but then just goes round again and makes you do it again and again and never gets past the same bit.
Then I try migrating from my iCloud backup....
And literally it doesn't like iOS18 😦
Don't really want to go back to June at all.
Ideally I need to upgrade this 15Pmax to iOS 18 beta (I need to send this 14pmax to an buyer on eBay like tomorrow! 🙀
Okay, well if that won't work then what I would do is go through setup without transferring data or your eSIM.
Then when you get into the iPhone, I believe you'll have to sign in with your Apple ID in order to get the iOS 18 beta option to pop up under updates. Update to iOS 18 beta, and once it finishes reset the iPhone by erasing all content and settings. This will NOT remove iOS 18 :)
After that finishes, you should be able to set up your 15 with the iOS 18 backup on iCloud.
That worked a treat !! Thanks! Thanks for your help! 🙌 by the way, out of interest, are the screen protectors the exact same side for a 15pm as my 14pm?
I don't believe so. The 15PM is slightly (Extremely slightly) smaller than the 14PM. It may work, but I would probably just buy a 15PM one to be safe.
