Help no sound on Doodle Jump
chrisrobertson56
Can anyone tell me how to solve the problem of the sound not working on Doodle Jump? It works on other games and is definitely switched on. Thanks
Have you found a solution yet? My iPhone 4S has suddenly done the same thing to me. I have sound for everything else, but doodle jump has no sound at all. It is switched on and the sound on the phone is not on mute.
I have the same problem. Never had it with my Touch, but do with my new iPhone (iPhone 5). It only happens after I have used the phone with earphones. If I turn the phone off and restart it, sound comes back. Until the next time I use the earphones. Presumably this bug will be fixed in a Doodle Jump update.
To be clear: After I listen to music, or talk on the phone using earphones, then unplug the earphones, the sound is missing from Doodle Jump. If I turn the phone off and then on, the sound returns to Doodle Jump. If I use the earphones again for music, after I unplug them, once again there is no sound in Doodle Jump. Turning the phone off and on fixes it, but that is a bit of a pain. Hope it gets fixed.
