Help With JailBreak... Iphone 4s
turbo
Today I tried to jailbreak my iPhone 4s using the snowbreeze software... not aware it was iPhone 4 only. Now I am stuck on the black screen.
I did some research and found an article which explained jailbreaking on 4s with 5.1.1. However when I try to restore the iOS to 5.1.1 I get a 3194 error. Again, after some more research I found this article on the ipadforums: HOW TO - Resolve iTunes Unknown Error 3194
I was hoping this would solve my problem but I still get the 3194 error.
Is there any way to restore my iPhone back to 5.1.1 so I can jailbreak or have I now f***** my iPhone? :(
Any help would be greatly appreciated.
Thanks.
You can't not downgrade to iOS 5.01......you might have bricked your phone....sorry
Thanks.
You will need to have SAVED you SHSH blobs for 5.1.1 to downgrade/Restore your iPhone 4 back to 5.1.1 firmware....NO SHSH blobs = NO DOWNGRADE
Seconded. Also, the way that the A5 devices (iPad 2 and iPhone 4S) work in terms of downgrading on iOS 5 is termed a re-restore. There is no real downgrade method aside from re-restoring because RedSn0w takes advantage of an exploit in the restore process that allows it to run smoothly without the need of Pwned DFU mode (not available for the A5+ devices). But like Bula said, without blobs, you can't downgrade. This goes for ALL iOS devices.
