help!
help!
kurds
terminal icon appears in my iphone.its useless what will i do to delete this?
Hi.Not sure if anybody can help.An icon has appeared on my iphone 3gs.Its a black icon with one of these >_ it is called terminal.I did not download and when i open it it just brings up the keypad for a flash and closes again.Is there any way to delete it.when i keep my finger on it theres no x to delete.Thanks
Go to cydia and install "cydelete" tweak to your phone, once installed, delete that application just the way you delete normal application you install from the app store. That app is "open ssh" or "terminal" or something like that.
