EyePhone4 said:My buddy has his 3GS and for some reason it's not connecting or finding his bluetooth, can anyone give us a hand thanks
reamom said:Tell him to try a soft reset. Hold the home button & the lock button at the same time until the apple symbol comes on the screen (it will take a minute) let go. He won't loose anything, if this doesn't help tell him to plug into the computer back it up and then reset the phonehope that helps
