- Apr 24, 2012
My bro gave me his 3gs. It was in pieces which was why he gave it to me, though I managed to fix it and get it working
I tried to jailbreak it at first but it was unsuccessful and crashed the phone, so I had to upgrade to the 5.1 firmware just to get it running again.
My problem now is that I need to activate the phone. I go through the settings process (country, language, wifi etc.), then when it comes to activating it tells me it cant connect to the network. So I put my pay as you go 3 sim card and plug into itunes to activate, it says my sim card isn't compatible?!
Also I asked my bro to ring up vodaphone and ask them to release the phone but he said he lost his account details and is just too lazy and hopeless to chase it further.
So my question is where do I go from here? I want to use this dam phone asap! Though havent a clue what steps to take. There are plenty of jailbreaking tutorials out there I know, but they all seem to at least have the phone activated and running (can see all the apps etc.) I need to actually get the phone to that stage :| also is there now a good jailbreak solution available for the 5.1 firmware?
Thanks
Thanks
