I need help with iPhone 4!
iPhoner101
I need to recover my iPhone but I need to put the code...
Problem is:
I can't put the code anywhere.
I need to put the security code to connect my PC.
___________________________________________
I can't put the security code, unless I connect my PC.
Paradox
HELP!
Is iTunes asking you to input the code because the phone is locked with a passcode...?
If you've set a pass code on your iPhone the first time you plug it into itunes you will need to unlock it...
I need to put the passcode into my device, but I can't.
When Im trying to connect the phone to PC, it says:
Cannot connect, unlock your phone" or something
Your phone must be locked with a passcode when you 'slide to unlock'. Just unlock your phone after plugging it into iTunes...
His phone is obviously stuck in a manner that wont allow him to slide to unlock and enter his passcode so he cant restore his phone.. unfortunately i dont have a solution for you man.
