In need of help..
In need of help..
IOSMonkee
I accidentally deleted my com.apple.racoon.plist
It's for VPN networks and now I can't send picture messages.
I have an iPhone 3GS and I'm on straight talk.
Do I need to restore or somehow find the plist and put it back in with I file?
You will have to restore.
I could zip up and send you mine....but u have an iPhone 4, so I don't know if it would work.
If you happen to know someone with an iPhone 3GS with the same iOS version that you have, then that would work..
But if you don't know anyone that can do that soon enough for you, then a full restore through iTunes is the only way to get it back.
I fixed it, thanks for trying to help. I ended up going into the trash in I file and copy/pasted back to the right destination.
