Internet doesn't work-edge settings seems to be correct
Guinevere
My iphone is jailbroken and unlocked on 4.0.1
Also my Voda- SIM is working well...and the internet was working until I had to change the SIM to a T-Mobile abroad, and back. Then, the APN-settings disappeared, but I solved it.
Here is the problem:
Besides the proper voda apn-edge-etc. settings (i've interviewed even the carrier's freaks), the internet does not work. I tried every settings, searching for apps to solve it, but I'm just not able to connect to wifi, vpn, anything.
Now, i'm going abroad again, so I do need this internet-access ...
Can anyone help me?
Any settings to change or I should turn it back to standards and jailbreak again??
im having the same problem right now and no fix yet.. have u got ur iphone fixed? because im probably need the same remedy. thanx
Being a year old and the user has 1 post I doubt you'll hear back from him.
