iOS 4.3.5 problem??
bm65944
I updated my iPhone 3gs two days ago to iOS 4.3.5. Since then I can not hear sound from any applications, the keyboard, or media such as YouTube or Vevo. The ringer works fine and I can make calls with no sound problems. I contacted apple and they said to just restore the phone through iTunes. I have done that about 4 times now but it hasn't helped. Is there anything I can do to fix this problem??
P.s. I'm not sure if it makes a difference or not, but my phone is not jailbroken.
There have to be something turned off by default in that iOS 4.3.5 try to go through the sound under setting, I'm saying that there have to be something turned off by default in the iOS because you have factory restore the iOS several time already, and your phone was working well before the upgrade, so go to setting and check everything related to sound one by one.
I've gone through and checked to make sure everything is turned on. Still having the problem.
