New to this so bear with me, I'll try to word it so it's understandable.
Problem 1: Have a Jabra EasyGo bluetooth headset but it doesn't seem to be working right when I have the phone connected via bluetooth. (Never had any problems before yesterday.) Seems that when I touch the button to answer the call it opens the "line" but I hear nothing in the headset. Sound comes from the phone but not thru the headset, but I can hear the clicks thru the headset when I enter the security code and it tells me thru the headset when I have a text or call coming in. (Did have an incident of loud "static" sound on one call yesterday but the caller sounded fine fine when I shut off the Jabra and went to phone sound.)
I have deleted the headset and re-installed it. The bluetooth indicator shows green on the settings page, The headset says "Connected" when I touch the button. The Devices line shows a spinning wheel. The Jabra EasyGo shows as connected but below that it reads "Now Discoverable". Is this all normal or is there something I need to do to get it back in proper working order?
Suggestions on #1?
Problem 2: Tried to reduce the number of app's running in the background by doing the "tap the button twice then hold down on one of the apps until it becomes shaky" but none of them ever became shaky or allowed me to "delete" them. Was wondering if there might be too many apps running for the phone to work properly so did a settings reset, and that seemed to remove the long list of background apps but changed nothing else. Clicking bottom button twice to get to the background apps works but I can hold my finger on one of those for a full minute and it never becomes shaky.
Suggestions on problem #2?
Thanks for any assists and I'll try to answer any further questions anyone may have when it comes to finding the solutions.
ffp
Suggestions on #1?
ffp
