- Jun 29, 2017
The iPhone 16 Pro series is rumored to get small display size increases.
There could be a 6.9 inch diagonal on the iPhone 16 Pro Max, up from 6.7 inches on the iPhone 15 Pro Max. Similarly, the iPhone 16 Pro will get a 6.3-inch display, a .2in increase from the iPhone 15 Pro's 6.1-inch display.
Funny enough, the original iPad Mini had a screen size of 7.9 inches. So 12 years later, the biggest iPhone is only an inch smaller than the iPad Mini. It's only a matter of time before the iPhone is as big as an iPad Mini!
Is a size increase enough to upgrade for you?
