iPhone 4 passcode problem
daniel1333
Hey guys, my friend downloaded a theme for winterboard and now the passcode keys are so small and at the corner of the screen so she can't even press those buttons.
So I tried to help but I ran into a few problems:
1. iFunBox doesn't recognize the iPhone for some reason.. Probably 'cause of iTunes.
2. My Computer isn't the default computer of the device.
3. iTunes wont let me do anything because it sais the iPhone is locked with a password.
4. DiskAid wont let me do anything either, it sais I need the passcode.
5. She has no SBSettings/adc2add installed.
The iPhone is an iPhone 4 GSM, running iOS 5.0.1 jailbroken with redsn0w.
I have no backup for the photos, songs or contact list! So I can not restore. I mean, I can but I rather not to
thanks.
Perform a Hard Reset... hold the Home and Lock buttons together until the screen goes black and the Apple logo appears. Disregard the "Slide to Power Off" bar when it appears as well.
Did she load a tweak at the same time as the theme? Have you tried to go back to Cydia and remove that latest installed item? Although, honestly, themes don't usually make a mess of the phone like that...
Regardless, if you can, get back to Cydia and UNinstall the stuff that was installed just before the troubles. See if that fixes it.
Marilyn
