Jailbreak iphone 4s ver 5.0(9a334) help .???
yanniss2012
thank you guys for taking time to read my problem . i have iphone 4s ver 5.0 (9A334) IT;S VERIZON i wanna jailbreak it in order to unlock it .
i could what are the steps please. im using windows computer and not apple . thx.
I dont know what carrier you would even unlock it to? do they have a carrier that uses that network in greece? I thought it was just GSM? there is no unlock for the verizon iphone though, if you where planning on using unlock when its released for the 4S you should of got the GSM version re gianni, it makes no difference what OS you're using osx or windows or linux..
To jailbreak omos you can use absinthe on ios 5.1.1
SORRY if you upgrade to 5.1.1 you will loose chance to unlock . and yes unlocking it with ver 5.0 or 5.0.1 using gevey sim for cmda. then u can use it with any network im not in greece im in usa
Verizon will unlock an iPhone 4s but ONLY for international travel.
