Lockinfo plugin order help
28offroader
I installed lockinfo, added the lock weather plug in (that has a clock) and then used clock hide for the factory clock. On my lock screen, lock weather shows below all of the other plugins. I want to be able to have lock weather at the top but havn't been able to figure out how to change the plugin order. If I go to the plugin order setting it shows the order but there is'nt any way to actually change the order. On all of the pictures of other peeps lock screen that has this the time was on top, I know it can be done just can't figure out how.
Nevermind, I figured it out. You need to go to plugin order and then hold on the 3 lines of which plugin you want changed and then drag it to a new spot.
