New iphone owner/user (5s)
I love this thing. I don't know why I waited so long.
I use this thing constantly through out the day. And the battery needs recharging through out the day.
Im planning on investing in multiple wall charger, car chargers, and an external portable battery recharger and lightning cables ( hyperjuice.. morphine.. )
1. The bigger the number in maH for your car cigerrette lighter the faster the charge?
For EX: a cigerrete USB charger with a 2.1 maH is going to charge faster then 1 with 1maH? And a 4.2 maH will charge faster then a 2.1maH?
2. If a cigerete USB charger has dual ports and is rated at 4.2maH. That's 2.1maH each USB port?
*Now is that 2.1maH when both ports are in use? What if you are only using 1 port? Is it still 2.1maH or is it 4.2maH? I ask because the guy @ B.B told me this?
3. What are some of the better quality lightning cables I want to buy? Will all lightning cables charge the device @ the same speed?
4. When using an external portable battery recharger such as hyperjuice or morhpie: This is just a charging device correct? You charge the charging device. And when needed you just connect your phone to the device and it will charge the device as if it were connected to the computer via USB or connected to the wall?
.......so confusing......
Thanks guys.
I've done multiple searches and got lots of conflicting info.
PS: I am using an Otterbox Armor case ( love it ). I am aware they make cases that have extra battery power. But Im not planning on ditching my Armor
Thanks guys.
