Need help fixing source error
dmitchstevens
ky
I get this error for the winterboard sourc. Can anyone tell me hoe to fix this?
How do I remove? When I go into manage -- edit . It's not able to be deleted this way.
Slide to the left over the resource and "Delete" should show up on the right in a red prompt box.
The winterboard source or the apt.saurik source neither will allow you to delete this way. All the other sources will allow you to swipe left to delete
Then you'll have to ssh the repo out. That's the only way!
That's what I thought. Can you tell me how I do that. I have ifile
Var--lib--apt--list edit deleted the two winter board files. Now do I respringing or reboot before adding back?
