Need Help : iPhone 5C & Otterbox.
xplodee
So I was just getting a bit worried about my 2 months old iPhone 5C (White) already dropped near 10 times.
Had a bad past with Broken iPhone's. So a bit worried now.
I was just checking around online for Otterbox cover for iPhone 5C. But iPhone 5 cover seems more safe.
So is there anyone here who is using iPhone 5 Otterbox cover on iPhone 5C ?
Or gave it a try?
I just wanted to know how was the fitting ?
Sent from my iPhone With My Permission.
Nobody? Wow
Been using otterbox for about 3 years. Don't have 5c tho.
As a generality some OB cases fit better than others no matter which you pick.
OB reps are very helpful and can either replace or repair most cases. Usually they just send me a new one as they are guaranteed for a year.
Hope this helps.
Hope this helps.
Oh. Thanks for some info.
Actually few Plastic Back covers were perfect fit on both 5 and 5C. So I'm asking here for Otterbox !
My wife has a 5c. She uses an Otterbox Defender. The first one she got from Verizon had problems. I called Otter and they sent her a new case that fit much better than the first one. All free. Great customer service. Protect that phone!
Is otterbox the only option you have? I am sure it will fit.
