Need help with calendar shift
Sitka910
Somehow my calendar has shifted dates. The calendar icon displays the correct date but when I enter the calendar, the days have shifted ahead 2 days. If I look at an event in the calendar, it displays the correct date. However the dates remain shifted in the calendar scroll view. Any suggestions to fix this?
In the calendar, when you tap on the correct date, then close the calendar app and reopen it again, what happens? Is it still shifting 2 days ahead?
Yes. I already tried shutting the app down I also did a soft and hard reset of the phone. It is still 2 days off. I am not sure what else to try!
Ok. I fixed it. I just deleted the last appt I added and it went back to normal. That was the strangest thing. Thanks anyway!
