- Oct 12, 2012
So before everyone starts jumping at this and telling me to just create a IPSW that allows me to enter DFU mode, please continue reading- its trickier than that
After hours of messing around, I was finally able to get my iPhone 4 to go into Pwned DFU using redsnow, use a stitched ipsw created with Tiny Umbrella, and accept the downgrade. With one little (although massive) problem. When it finishes, I get the iTunes error (-1). Normally, all I would need to do at this point is use my power and home button to go into DFU and I would be DONE. But I cant. And I cannot use a different IPSW to go into DFU because that defeats the whole purpose. I also cannot use the recovery fix in Redsnow or Tiny Umbrella because i need to be in DFU in the first place to do so.
What the hell do I do? PLLLEEEEEASSSSE SAVE ME!!!!
I have a feeling my only way out is to know how to do the downgrade without getting the error (-1). Do I need to tweak my hosts file to do this? On a side note, why does iTunes only work from my work network and not from home to restore my phone. Where does it specify an IP or something that locks me out?
Thank you all so much for your help. I really really appreciate anyone who reads this and takes the time to think about it, and even more if someone helps, and even MORE if someone gets it to work!!!
