Syncing help
Syncing help
jtstretch
sorry but ive searched and didnt get answeres. probably cause i dont know what to really look for. a couple things, when my iphone syncs in itunes where are the contacts and calender syncing to and how do i get there? next is if i cant get there what are my options to sync them some place else? basically want to be able to edit both and when i sync they will update in phone. i got a PC so this may be why, i dont know!!! Thanx for the replys
Plug your phone into iTunes and select it form the bar on the left. There will be a row of tabs at the top. It's either the first or second tab that has the options to sync contacts and calendars. Sorry, doing it form memory...
After doing what gaz said above, you can choose from the list of programs you have installed where your phone syncs to. Default is Microsoft Outlook I believe, but you should be able to sync with Windows Mail/Address Book, or Mac's version if you have that installed.
