- Jun 16, 2012
zig9449 said:Um.....I don't get it.
What are you trying to fix?
It looks like the same background that comes with Absolution theme.
I have the same exact theme.
triggergun said:Mine did the same. SSh into the theme you are using and find the wallpaper you are using..."the black one..." copy that background and save it to your pictures folder. Then, on your phone select that picture and set it as wallpaper. The theme will then show that wallpaper when folders are open,
Dark Dragon said:Im still new to ssh, how can i do what you mentioned above?, i mean give me the commands, my theme is absolution.
triggergun said:no need to take a screen shot ,, when you find the wallpaper copy and paste to desktop. Then go to camera and drag the wallpaper into your camera . Then on your phone, open your photos, select the pic and set as wallpaper.
Dark Dragon said:Zig, thanx, i gone to iFile, and gone to var/stash/themes.dIYCXX(i think that was.dIYCXX) anyways then i opened absolution.theme and found the wallapaper there, okay im done but if i want to learn more how to ssh through files,etc.. How can i do so?
zig9449 said:You already know how to SSH....
You just did it.
Every time you need to SSH...or use iFile to get to a certain DIR(Directory) then you just follow the path.
For example:
Back up your SMS messages to restores after a restore and setup as new device.
var/mobile/Library/SMS/
Drag "sms.db" to desktop.
Now you messages are saved.
After restore...and jailbreak....place sms.db in the same path..and all the messages will be there from before.
All it is is following a simple path....most of the time.
You can use i-FunBox to access the file system from the computer...or use iFile to access the file system from the device.
With certain task...one is preferred over the other. Some things are easier with iFile....some easier with SSH. (yea..using iFile really isn't considered "SSH"). But the same thing really.
