Urgent help photo stream
drdrake
How do you delete photos from the section called photo stream please? I know it sounds easy but there's no option to delete
last time i looked there was no way,i just deleted photo stream then re installed it or you can wait and after 30 days they will disappear any way.
Quickest way is to disable it in your Camera Settings... then log into your iCloud account from a PC and clear your Photo Stream from there. Supposedly, Apple is going to add an option to delete from Photo Stream w/ the iOS 5.1 update.
it was a bad move on Apples part not to include a delete option so it will be very welcome.
