WIWOFIT Wireless Charger Review ( Iphone 5s )
charliehill
Choose right charger is important, I use Iphone 5s , it's OK except lousy battery life, I kill power with movie that's why got WIWOFIT Wireless Charger from Amazon (Also need a Qi-compatible receiver ), someone suggested CHOE Brand, it's good but I pick this cheaper one, It charges fairly quickly and because of the rubber ring the phone stays planted on the charger very well and wont vibrate off the charger if you get a call. I really have nothing to complain about especially at the such low price. It looks cool works well and was a good price, I don't need External Battery any more.
General Impression of WIWOFIT Wireless Charger
Good: Cool circle design
Not big, easy to carry
Response quickly
Works well
USB cable is stronger and long enough
Just so-so: no color option, only black
Needs a little bit longer time than cable charger
Bad : Not found
