Jmills87
Well-Known Member
So just don't download them while you're not around a computer.... simple.
Jmills87 said:So just don't download them while you're not around a computer.... simple.
Jmills87 said:Any applications that modify mobilesubstrate or the way the phone operates or functions require reboot. All other apps require respring or nothing at all. Just install all the apps you want when you're at home near a computer and then if you're on the go at some point and you want to install an app that requires reboot just wait until you get home to install....it's really a small price to pay to be jailbroken.
My phone was tethered during 4.0 for 2 months, I never once rebooted it without a computer near me. It's really not that big of a deal. Just keep your phone charged and don't install any Cydia packages that require reboot unless you're near a computer.
Seems like it's going to be a few months before they release iOS 5 so seems like it would be worth it.
ClemsonMarshal said:Redsnow will do a tethered jailbreak. But basically, there may as well be no jailbreak at all if tethered is all that exists...because tethered SUCKS!! I don't know if I can wait until iOS 5! It takes like a week for these people to make a jailbreak...why not make one for 4.2.10?!
holophyte said:What's the difference between tethered and untethered?
IFaith V1.1 looks a little scary. Running Jailbreakme 3.0 on Verizon 4 CDMA 4.2.8. Runs great and smooth. No problems at all. Tried Tiny umbrella no luck saving SHSH blobs. Is I faith easy to use? looks like it may take device into DFU mode and with jailbreakme never had to do that. Also what is the Cydia patch I need to do the security update that 4.2.9 and 4.2.10 protected against? Love that Jailbreakme. Just want to make sure I am covered and stay at 4.2.8 until 5.0 comes out. Jailbreakme makes a great device even better
