sourdoughjosh
In my case the issue is specific and repeatable:
iPhone 4 (with iOS5) works fine in the juicepack air, regardless of setup.
iPhone 4S works fine *when the switch is set to the off (red) position.* That is, if the Juice Pack is *not* charging the iPhone when you plug it into the wall, it will begin charging the iPhone just fine.
However, if the switch is set to the on (green) position, and the pack is charging the iPhone 4S prior to plugging it in, the iPhone will display the error message discussed in this thread.
I do not have another iPhone 4S to test, unfortunately. I would be curious if others here could test theirs in both switch positions and see if it's repeatable.
EDIT: This behavior is specific to using a USB power supply, and does not occur when connecting the cable directly to a computer USB port. Have tested with a variety of USB power bricks (both Apple and 3rd party) with same results.
Thanks,
Josh
Thanks,
Josh
