p3unit32
Skull One said:You are able to get 9 hours of mixed usage and 24 hours of standby time on a single charge?
I don't think I will get those number, but I believe I can get close to 7, 7-1/2 hrs usage. I can be content with that.
My posts are to correct ignorance 99% of the time. And I do that because I firmly believe everyone should be empowered with knowledge. I never even bother to respond to someone that has gone beyond ignorance and crossed the line of stupidity. So if I answer something or someone it is because I believe, 100%, that the person is not stupid. Which is the exact opposite of what you think of me based on this post.
I waited for quite a few post for someone to chime in and state what I finally had to post. I don't want to answer everything here. It defeats the very reason for the community to exist. I want people to be able to answer things for themselves, and others as well, and to be able to defend it properly. In this case it simply didn't happen. So to get this thread back on topic, I decided I would truly end that part of the narrative so we can go back to original topic. Which is, what bugs in iOS are causing the battery to drain to quickly on the iPhone 4S.
BTW, if you knew the correct answer and the full reason for that answer, I am curious why you didn't post it.
That is a loaded question. The correct answer, in my opinion, is that you can do everything within reason during your daily activities without having to stop and recharge.
For me, I believe that I should be able to go 8 to 9 hours of on screen usage with a minimum of 16 hours of standby time. That mixed usage would consist of being able to have 4 push mail accounts with 20 emails, 20 texts, 1 hour of phone calls, 1.5 hours of gaming, 4 hours of web browsing on WiFi and the ability to take at least 10 pictures.
Not much difference in how ive used the phone, since the first time after the reset. Only difference is I used waze for about 20 min this morning. Everything else is mild usage. I have 32% left with 4 hrs 1 min usage and 21 hrs stand by. This is with everything turned on except push for apps, since i dont havent readded all my apps yet.
How does my usage look? Am i getting what I am suppose to at this point? Thanks
gixxersixxer said:This is such crap! Got rid of my iphone 4 which had good battery life, to upgrade to this and now i have to watch how i use the phone and change settings just so i can squeeze what i can out of my latest and greatest phone! Good job apple!
1. Please keep this discussion public, not private - it is an interesting and very misunderstood topic.
2. The following references are but 2 of many on the subject:
http://www.intersil.com/data/an/an167.pdf
http://www.analogzone.com/pwrt0207.pdf
3. I am not an expert on this subject (by far), but a cursory examination of the above 2 references appear to imply that the cell-leveling requirement is built into the electronic controller for the battery and thus transparent to the user when it is performed (all the time?). This in turn MAY imply that "user deep conditioning" is primarily for battery meter calibration.
I would appreciate any feedback anyone can provide.
Thanks,
Harvey
Be patient friend, it'll work out. Have you tried taking it back, or better yet restoring the phone as a new phone? If you do this you have to manually download everything, and not use those old backups which contains the bugs. Good luck!
You just made me smile, thank you.
Your 3rd point is VERY valid and something that Wikipedia and several other public blogs don't begin to address which is why there is soooo much confusion on the subject.
The first PDF beautifully states something I wasn't willing to debate because I couldn't factually back it up off the top of my head, which is why I smiled. Battery makers, in the larger voltage ranges, always match cells based on factory certification testing. Mainly because they are using self contained cells (IE double A batteries sized cells or larger) in a parallel, serial or mixed configuration for the device. Which means the the weakest link rule gets magnified greatly. On cell phone batteries, this doesn't happen however, because they tend to make much smaller cells in series due to only needing 4.2 volts max.
Your second PDF almost covers the rest of the narrative. It is really a shame though that it doesn't cover Stage 1, Stage 2 and Stage 3 charging cycles as part of its discussion on Lithium-Ion batteries. So in a sense that PDF is an "incomplete but close enough" for the topic at hand. Yes, typically the battery charging circuit carries the load balancing feature but unfortunately that isn't always the case. Sometimes the charger has the 3 stage circuit built in. And if the charger skips stage 2, then load balancing can suffer greatly.
If memory serves, cell phone charges up until 2007/8 usually carried the circuitry. 2008 saw the switch over and probably since 2010 I have seen a rapid drop off of chargers carrying the circuitry in regard to cell phones. Now non-cell phone devices is a whole different subject matter. A lot of them still carry the circuitry based on my observations.
Oh and the reason that there was a switch over where the circuitry was carried is because of USB port charging![]()
Please don't even remotely sweat it. Seriously. This issue is NOTHING compared to what Android users have to deal with daily and with every new phone released. Even the 4S with this issue will never come close to what happened with the Thunderbolt. The T-Bolt battery could drain in less than 4 hours and the only thing the user had to do was turn the phone on and then never touch it. The issue? The bloatware that was loaded on to the phone was running in the background once the phone was turned on. And the user COULD NOT turn the app off from launching.
So count your blessing that Apple only has a "slight" issue with this battery situation. It can and will be fixed soon. The T-Bolt took over 2 months before the first patch was even considered. It took less than 3 weeks for Apple to respond.
I still have faith.
So I guess the pertinent question is, specifically for the Apple iPhone series, is the cell-balancing circuitry built into the battery pack or possibly the included charger? Is there a way to determine this from Apple supplied tech literature?
Harvey
