Battery percentage
Battery percentage
That's weird, I have a VZW iPhone, and mine gives me the option to have a percentage next to my battery. I had seen it before, but never had chosen to activate it, but it's exactly where they said it should be, in Settings, then in the General menu, and it's the first option in the Usage tab.
It is there with the Verizon iPhone 4. Go to Settings, general, usage, slide the first battery percentage to on and it will show up on your home screen.
Same for me I've had it on but I took it off
I have a Verizon iphone 4 running 4.2.6 and it's j/b. I have been trying to find a way to make the battery percentage appear next to the battery. Various apps have been downloaded to place the little number there and no such luck. Any suggestions?
Its there man, under settings, general, then usage!
