Best wired earbud headset
zipur said:
How about the fall out effect do the buds stay in your ear?
If I use the small buds it stays good but then I have to compromise in the base dept and if I use medium then base seems strong but that is when it starts falling.reviews made an awesome mistake...they said tht its very comfortable but never mentioned for how long it stays in ear..well may be coz of my ear also but I think I also saw somewhere that even they have the same problem..
iCrank said:
I love the apple headphones. Can't help with finding anything better but you should check out headphones.com..
And I don't like mine lol. I still have them in the iPhone box lol. People can hear your iPod through them AND I can hear theirs, UGGHHH. I have the blue Sony ones that fit inside the ear. They are virtually noise canceling ( they don't make that claim) which is very necessary on public transportation - loud talking, loud iPods.
Sent from my Verizon Black 64GB iPad 2 w IOS 5.0.1 Update using iPF.net
The apple earphones fit in my ears perfectly.. But i agree the sound aint all that atall i need to find a replacement soon. I cant use the ones that go directly right into your ear they give me bad earache after like 45mins use.. They are great for noise canceling though :)
Earache wow!!! Maybe the headphone type. They are great when traveling and easy on the ears.
Hands down, Skull Candy is not a pair of headphones you want to invest in.
I'm currently using JAYS. It's really not that bad, I wouldn't know till I've used them a bit longer.
Wow jays are like next level of awesomeness in sound quality.i do like my klipsch s4i.apple uses dual drivers but they lack in bass department I must say although they Are not half bad.for pure audio quality at a reasonable price u may switch to s4i
Take a look at the sol republic amps earbuds. They sound awesome and fit great. For $59.00 I don't think they can be beat.
you can buy one to have a try, and if you don't want to go out, you can try online shopping.
I think the in the modern time when the technology is improve all the thing are going to be the smaller,like the headset ,charger, from telephones to the Internet connection every thing is coming in the smaller thing.From this types of smaller thing we have the most advantages is also,Like if we want to connect the internet from the out side of the home or from anyway we have no excuse because the wireless connection is always helpful for them.
