Charging issue
Charging issue
Your battery percentage indicator just needs re-calibrating. It can be done by running the battery down then fully recharging it.
Didn't you forget about the hard reset afterwards. [emoji6]
Sent from my iPad Air using Tapatalk
It takes my iP 5 about 4 or 5 minutes to "get useable". I've never known an iPhone to take 30 minutes. But then, I don't have an iP 6 or 6 Plus. ☮
Note: If you use your phone while charging, you can shorten the charge time by about 3 or 4 minutes by turning on Airplane mode.
Sent from my ancient but trustworthy iPhone 5
30 minutes to boot up your phone again is fairly long.. Do you use the original Apple lightning cable? or... do you use a 3rd party cable?
