Connecting to car stero with Auxillery input
Hourvitz
Hello, my car stereo has no auxillery input and no casette tape player (it does have a cd player). What is the best way to hook up my iphone to utilize the car speaker system?
Thanks,
Thanks,
The cheapest way Is to get an fm transmitter then tune your radio in to your iPhone. The better option would be to just get a cheap deck installed in your car that has the aux port in it.
FM transmitters sound bad and are a hassle. The tape player thing doesn't sound too good either.
You have any better suggestions?? Installing a new deck is really the only way to add features to a cars audio that it doesn't come equipped with....
actually, i went to frys for for like 90 bucks or so, i bought a cable, but thing is you have to sacrifice your CD player in place of your ipod/iphone, there was one for domestic cars and import cars, not sure if they still have it, but its clear, no static, no nothing
If you could afford an ip4 you should be able to get a deck? It is the best way IMO.
Yo u dont wanna use ur iphone for music in ur car, TRuST ME ur gnna get a headache
I only listen to two thing in my car.
1. MY IPHONE
2. XM radio.
Ive never put a CD in my radio(iv had it for more than two years) and i don't even think i have any pre-set's set on the radio. I use the iPod cable for my phone (i have a Pioneer head unit), I can also use it through BT, and i also have an AUX that my friends sometimes use when they ride with me.
i use my ipod 24/7 for music in my car, and i dont see why you would get a headache listening to your iphone which ive done a couple of times, and i felt perfectly fine
antenna wave crap? mine sounds perfectly clear? what do you use to connect your ipod to your radio? i have a cable so its direct
ahhh, im not sure which one i got lol, cos i had to sacrifice my CD player for the ipod but hey i mean it was worth it
If you decide to get a new deck, get the one with a USB input. The difference in sound between the USB input and RCA jack is like night and day. You can pick one up for about $100.
Sent from my iPad First Generation WIFI/3G
