Jmills87
Well-Known Member
Yes it is jailbroken now. Sn0wbreeze creates a pre-jailbroken firmware with Cydia pre-installed so that as soon as you restore the firmware you are jailbroken.
If your phone had ever been jailbroken before it is quite possible that Cydia automatically saved your SHSH for you.
If the phone was lost or stolen and the original owner reported it, then your phone is on the blacklist and it will not work with any cellular provider. Not even if you use the Gevey SIM. There is no way to remove it from the blacklist either if that is the case.
